RockCeramics
Not sure if i,ll get an answer here, but as they say you dont ask you dont get.
On previous work i have been able to do this line of work but not on this scale so very unsure if my quote would stand.
Got asked if i could give an estimate on a chemical clean once all contractors have completed works before hand over. I have approx 2000+ m/s of terrazzo flooring to strip and polish. These areas are in different areas and not a continuation (some areas will have to be done in sections per shift,so could end up with joins in polish.but hoping to get this ressurected.)
Due to the size woundering if the £m/s rate should drop.
So my question would be do i drop my rate or raise depending on meterage?
or do on a shift rate pattern?
