ardex k15 will go beyond 10mm with no chippings so 10mm will be no probs.......dave..
[FONT=Arial, Helvetica, sans-serif]
Level Over:[/FONT]
Concrete[/FONT]
Ceramic[/FONT]
Wood[/FONT]
Cutback adhesive residue and more![/FONT]
[FONT=Arial, Helvetica, sans-serif]Portland cement-based, high-strength, fast-setting, non-shrink underlayment. M[/FONT][FONT=Arial, Helvetica, sans-serif]ix with water, pour or pump, spread, ready![/FONT]
Product Capabilities:
For use over concrete, metal, terrazzo, ceramic tile, wood and old flooring adhesive residue (including cutback), on above or below grade.[/FONT]
Pourable or pumpable. Installs from featheredge to 1 1/2" in one operation; up to 5" with the addition of proper aggregate. Designed specifically for fast leveling of floors, ARDEX K 15 provides a durable, flat and smooth floor surface with minimum labor and installation time.[/FONT]
ARDEX K 15 hardens quickly by hydration and drying. It will not shrink, crack or spall, even when applied in thick layers. Floor coverings can be installed just 16 hours later.[/FONT]
ARDEX K 15 is recommended and specified by most flooring manufacturers, architects, and contractors.[/FONT] [FONT=Arial, Helvetica, sans-serif]
4100 psi.[/FONT]
Benefits:[/FONT]
- [FONT=Arial, Helvetica, sans-serif]Portland cement-based[/FONT]
- [FONT=Arial, Helvetica, sans-serif]Installs up to 5" thick [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Designed specifically for fast leveling of floors [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Use to level and smooth interior concrete, terrazzo, quarry and ceramic tile, cutback adhesive residue, wood, and metal [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Walk on in 2-3 hours [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Install floor covering after 16 hours[/FONT]
