Tony Cooper
Hi All,
Anybody have any recommendations as to the best way to mechanically fix 12mm hardi backerboard to a plastered over brick wall ?
A customer has had a job fail and asked me to fix it. A now out-of-business bathroom company fitted 900mm x 300 x 10mm ceramic tiles full height and 2 tiles wide above the bath side and 1 tile wide above the taps/shower end. The tiles have fallen off the bath side after just 6 months. (The shower side column is fine). There's only four tiles left on the wall directly above the bath, 2 wide and 2 on top. And where they meet in the middle they've bowed. At the top of the tiles there's a gap of approx 25-30mm behind the tile and the wall and the addy has de-bonded completely from wall. The plaster is completely undamaged - never seen anything like it. Apparantly the bathroom company plastered the wall one day then tiled and grouted the next, unbelievable. No wonder they went out of business.
Anyway, I'll need to pack-out the wall because the bath wasn't fixed flush to it which is probably why the bathroom company just dot and dabbed a huge amount of addy to pack the tile out so it sat on the bath edge. Customer tells me the wall is brick which was then plastered over.
So, my thoughts are to mechanically fix cement boards (approx 4.5m2), so how would you guys go about mechanically fixing them (into a 6mm bed of adhesive of course)
Thanks in advance.
Tony
Thanks in advance.
Tony
