H
Hayden Goy
Hello all,
i have purchased some underfloor heating insulation boards spec below:
PropertiesStandardUnitDataDensityEN 1602Kg/m²38Thermal conductivity, 90 days, 10°CISO 8301W/mK0.027Compressive strength at 10% deflection or yield, (vertical)EN 826kPa350Compressive modulusEN 826kN/m²12-20,000Tensile strengthEN 1607kPa500Tensile modulusEN 1607kPa12-20,000Shear strengthEN 1209kPa250Shear modulusEN 1209kPa8,000Design compressive stress, <2% compressionEN 1606kN/m²110Water vapour resistivityEN 12086(Uu)- value100-160Water absorption by immersion (28 days, full boards)DIN 53434Vol-%0.5Capillarity-nilnilCoefficient of linear thermal expansionBS 3837: Method 13mm/mK0.07Temperature limits-°C-50/+75Fire classificationBs 3837:
Pt2: 1990--Edge profile--buttSurface finish--planed
whats the best tile adhesive? i've got at the moment WEBER.SET RAPID SPF i've put some on the boards to try first to ensure its ok but not sure as its been on about 3 hours but it lift of quiet easy do i need to leave it for long to dry?
I purchased the boards of ebay
Insulation for underfloor heating 10 Pack 10mm on eBay (end time 08-Sep-09 13:56:26 BST)
but i know little about adhesive and the best to use. also i'm looking some adhesive to sick these boards down with onto woodern floors, i got with it GRANFIX ACRYLIC bonding & priming agent but dont know what this is for?
Is this a primer for sealer for concrete?
thanks all
thanks all
