Discuss 50mm thick french limestone ? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Time's Ran Out
@bluesky - 50mm thick is only one aspect! Tile size is required and substrate as asked by others. Bit more info then advice can be given.
Good luck.
F
Flintstone
I just think 50mm thick is substantially thicker than most stone, Like 4 times thicker, and a lot tougher
Dan
Admin
1,318
Staffordshire, UK
Like a quarry though, you only need to have a crack in the first bit and the rest will follow. It's like the biscuit on the back of a ceramic. Doesn't really matter how thick it is.
To be fair it sounds to me like external kinda grade if it's that thick? Does the builder just have some left over from a patio or something?
Dan
Admin
1,318
Staffordshire, UK
Jesus christ I didn't realise there were so many types!
Limestone Tiles | Limestone Floor Tiles | Limestone UK - http://limestoneuk.com/
You're probably right mate, maybe it's a super solid one at 50mm thick. When I'm picturing limestone, I'm picturing the kinda stuff walls are made from that weather away after a few years. Crumbly weak stuff.
Perhaps my lack of skill and experience are showing through on this one matey.
Reply to 50mm thick french limestone ? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
Hi all. As title suggests. Used to use this forum a while back but seems my account was deleted...
