Currently reading:
Help with lining up wall grout lines
Discuss Help with lining up wall grout lines in the DIY Tiling Forum area at TilersForums.com.
Hi, hoping someone can help with advice.
We purchased 600 x 600 tiles for our bathroom floor, and 300 x 600 rectified tiles for our bathroom walls. We are using a satin white on the walls, and a charcoal tile on the back wall of the double shower as a feature wall. The charcoal tiles match our 600 x 600 floor tiles. All to be laid with 2mm grout joints. Well, that was the plan anyway. We have just discovered that the charcoal wall tiles are actually 298.5 x 600, not 300 x 600. This means that the grout lines will not quite match up with the white tiles on the side walls of the shower. How to we overcome this? At this point we are thinking we will need to return them and look for something else. Which would be a shame as they match the floor tiles.
19
223
Bucks
I come across this problem a lot when customers buy tiles thinking they are the same size but a few millimetres out is a problem trying to line them up. You can try use 3mm joints so you have more play trying to line them up but at some point it’s gonna run out as they arnt exactly the same size. If it bothers you that much I suggest finding the exact size so each tile lines up perfectly. If your going for colour matched grout that are the same shade of the tiles helps blend it in if it does run out also if once everything is fitted it isn’t gonna be that noticeable from the floor transition too the wall at the bottom I wouldn’t worry about a few millimetres it’s only more noticeable when you look at a bare room without sanitary ware fitted. Hope this helps !
19
223
Bucks
You can only match up 2 walls minimum unless they are all the same size tile floor and walls this is a recent one we tiled all the same size but only 2 walls can be matched up unless all laid one way.
Thank you everyone. It was were the two walls meet that we have the issue. The floor tiles are fine. We measured out the wall playing with the grout lines, but as we are doing floor to ceiling, as mentioned by Samerlan the futher up we go the further out the grout lines become. We are taking these back and going on the search for new tiles the correct size that will match with the rest of the room. We really wanted to stick with 2mm grout lines, so this seems the best option. Appreciate the replies :)
Reply to Help with lining up wall grout lines in the DIY Tiling Forum area at TilersForums.com
Hello, after watching so many instructional videos and planing, I just can't understand how to tile a simple drywall construction in our bathroom. I got some good advice here so I hope you guys...
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
Hi all, I'm hoping you can help with some feedback, please My parents are currently having a new bathroom installed, all stripped back to bare walls and floor. The fitter has done/hasn't done...
Hi all, My 1st post and just wanting some help/reassurance on a DIY bathroom refurb. I’m putting down 800x800x10mm porcelain floor tiles. Floor area is 2m x 2.7m, 18mm chipboard. I added loads...
