Discuss Do I need to use Anti Fracture Matting in the Canada Tile Advice area at TilersForums.com.
38
Scotland
Hi all. I am looking for some advice on above subject. I am not a tiler but I intend on laying very large format 22mm slightly uneven hard limestone tiles inside on a concrete floor and want to know if I need to use this matting. The floor is 3 inch concrete, 100mm insulation on top and another 3 inches of concrete on top of that. This was done in early 2015 and we've been walking on it ever since. I can't see how it will be subject to movement and don't want to use the matting but I Sally would like some advice please. Many thanks
Lorenzo
Time's Ran Out
Are there any cracks in this screed?
3 inches then 100mm then 3 inches! Even I have moved on from radiogram.
Is it concrete or sand/cement?
38
Scotland
Hi, thank you for your response. Had a hectic day so sorry for taking so long to reply. The concrete came premixed from a cement truck. It was sand, cement and aggregate. It may have even come with fibre reinforcement but that was 4 years ago and I honestly can't remember. The area I want to lay is 6m square hallway which leads to a 14m square boot room. There are absolutely no cracks anywhere or deterioration of any of the concrete. Before I laid wooden flooring in the 36m square sitting room, there was no cracks in that rooms concrete floor either.
ar2ro
31
LONDON
It's two ways to make sure if limestone even 22mm can't crack special if it's there under floor heating. The best way will be lay down Schluter ditra25 matting or self-levelling compound min 5mm with fibreglass mesh. And very important to prime floor before lay any stuff before lay any powder compound including tiles adhesive. PVA is not good!
The best stuff it's this:
Link removed by moderator
38
Scotland
Hi Wilder. Thanks for reply. There is no underfloor heating. And I'm going to go with your recommendation. I don't want to over complicate my first job unnecessarily.
Been trying for last two days to find this post. I'm new to this site and forums in general so that's why I took so long to reply. I'm rubbish at navigating this stuff.
Could you Also help with the following. I tried to post it but the system told me I need to include at least one valid member and I don't know anyone so can't post it.
Hi, I was wondering if anyone can recommend a decent brand of tile levelling kit. The tiles are limestone. 22mm thick and some probably thicker, roughly 560mm x 850mm, I will be leaving a 10 to 15mm wide joint. Any recommendations would be very much appreciated. I have searched but I can't find anything that can deal with the specifics of my job.
Many thanks
Lorenzo
Bill
Many thanks
Lorenzo
For joints that wide you will not need a levelling kit, just use a 60cm/100cm spirit level. I know in the photos below I am using a 180cm level but for the next row, I start with a shorter level.
If your floor is sub level enough, then you should have no problems getting a reasonably level floor with spirit levels. Grade the stone into thickness as that will help.
Frodsham Barn-10001-2.jpg Frodsham Barn-10002-2.jpg Frodsham Barn-10010.jpg Frodsham Barn-20005.jpg Frodsham Barn-20006.jpg
widler
1,328
England
As tom says you won’t really need clips, especially with big joints , you will find with uneven tiles you will get the odd lip here and there , you can’t get uneven tiles lip free as theres always dips or high spots on the tiles .
Reply to Do I need to use Anti Fracture Matting in the Canada Tile Advice area at TilersForums.com
