Discuss Moisture meters for anhydride in the Canada Tile Advice area at TilersForums.com.
Nope. Not recognised in any I've the standards or industry guidelines. Carbide bomb, oven dried sample or hair hygrometer are the 3 recognised tests but carbide bomb is by far the quickest and most accurate. I used to recommend the hygrometer but since information from independent testing happened i prefer the carbide bombWhat do you make of the Tremex meters Alan?
Yes it is, no it doesn't, no it isn't and only in a controlled mannerNot the easiest to test properly It has a tendency to dry patchy
It's mostly used with UFH anyway
Grind the top off and wack the UFH on
They may well be very good but for moisture measurements are only recognised by any scholarly sources and British standards as a rough survey tool. They are not a recognised test under any standards so I am not able to recommend them. When thin screeds particularly with underfloor heating are concerned I have found them to be very variable in levels of accuracy. They can of course be used to find wettest and driest areas so that the best test areas can be selected.Tremex are very good
Tramex can take measurements in relative humidity % either by plugging it into a hygrometer box or the plug and probe method
No offense intended Spacey but I been doing this a long time. I know what the Tremex meters do. When I was with my previous employer they did lots I've trials with us but they didn't work consistently enough to be anything but a survey tool.
@Spacey your picking an argument about screeds and any related technical issues with the wrong guy here, tread carefully or you could end up looking the fool!Who was that then ?
FITA NICF and The Bourne's Say they are super accurate?
Who was that then ?
I didn't say it's used solely electrically That's only a scan mode to determine where to drop your boxes or drill holes for plugs Same as if your using an MMS
BS is in RH% only
I don't doubt your credentials I just said it's a good machine
You are right they are good machines and have their place but not for testing Anhydrite other than as a survey tool.
Not many people carry a CB test in there van tbf and even more don't test anything at all.
Reply to Moisture meters for anhydride in the Canada Tile Advice area at TilersForums.com
