Currently reading:
cuts inside of windows
Discuss cuts inside of windows in the UK Tiling Forum area at TilersForums.com.
hi m8 do u just mean time wise or are you have problems measuring your cuts? you should be able to mark your tiles the same way you do all your other cuts, then i usually put the cut edge to the inside and the good edge against the trim, then grout and silicone. no sure if that helps you much if not sure some1 else will have more tips and mayb able to explain it better.
John
Nah, 'bout sums it up I think.
Reply to cuts inside of windows in the UK Tiling Forum area at TilersForums.com
  • Sticky
