Currently reading:
Using expansion joints
Discuss Using expansion joints in the Australia Tiling Forum area at TilersForums.com.
Summary of Floor Movement Joints BS 5385
Interior & external floor tiling: divided into
maximum fields 10 metres in each direction
On suspended floors tiling fields should be
reduced and additional joints included over
supporting walls or beams
Movement joints should be incorporated over
existing structural movement joints
Perimeters, door openings, columns, kerbs,
steps, where tiling is continuous across junctions
of different base materials.
That's just a copy and paste, it will vary depending on floor type, tile size etc, on large floors using 600x600 we used to go at 4.5m
Reply to Using expansion joints in the Australia Tiling Forum area at TilersForums.com
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber floor in our barn conversion. The area is large, 21m x 8m. Having spoken to various UFH suppliers I...
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
