L
Leatherface
Here's a tip to anyone who doesn't know...
If you experience problems with travertine, where some of the filler has come out, or if a small hole appears in one of the floor tiles, there is a purpose designed repair kit called JOLLY MASTIC. It is a 2 part resin based product, comprising of paste and hardener. Just mix a small amount together with a few dots of the hardener supplied in a separate tube. Smooth over hole with a stanley knife blade. Scrape off excess. Allow to harden - does this quite quickly. Once set is dries extremely hard and is polishable or sandable. Comes in a number of different colours - best one for travertine is "vertical straw" as this is almost identical to the filler on filled trav.
