Discuss Transition Question in the Canada Tile Advice area at TilersForums.com.
dantheram
I have decided the best layout for my floor is to realign my pattern to give a whole tile at the 2 french doors i have. this leads me to the question of how much of a gap do i need to leave in order to fit a transition strip here -
the current gap here is 4mm on the bottom left tile (same as grout lines)
Thanks,
Dan
dantheram
Up to you really as long as the transition strip fits in and covers the gap.
Can't say I'm a fan of your layout!
ignore that top row, that's where the tile ends up if I run straight off the centred lines. I'm not having a crazy staggered joint setup like that.
Im in just having straight course.
See the problem is I know nothing about the strips! How much of a gap do they need to fit between the door edge and tile?
I
Ian
There are so many strips to choose from, it's quite difficult to answer your question. Have you seen one that you might use?
dantheram
Probably best if I use a hardwood one to match the door. I'm asking because I've seen some that drill into the floor and others that have to be inserted under the tile. I don't want something silly like this to bugger my whole floor up.
I
Ian
Get your strip before you start tiling, I think that's the only way to know for sure.
cam_low
Points
1,048
South Woodford
Like you say... Some have different systems. I like the ones that have ridges and push to height of floor.
Buy the one you like before fixing your tiles.
Reply to Transition Question in the Canada Tile Advice area at TilersForums.com
