U
Uheat
Hi Guys and Gals,
For All those that were at the training Day yesterday and took part in the quiz here are all the questions and answers for future reference.
1. What is the Watts/m2 used for Internal Applications?
160w/m2
2. The Aube TH132AF is rated to how many Amps?
15 Amp
3. What is the guarantee with the cables and Mats?
Lifetime
4. By what other name is underfloor heating Called?
Radiant
5. How many metres of cable would you have with a DM550?
55
6. Name one of the things you must NOT do when installing ufh?
Cut The Cable
Cross the cables
Closer than 50mm spacings
7. What is the Rule when sizing a Mat?
85-90% of the Free floor Area
8. What is the most common Thickness of Insulation Board used with ufh?
10mm
9. What is the approximate heat up time using an insulation board?
30-45 Mins
10. What is the largest single 200w mat we do?
10m2 or 20m long
Once again thank you to all that came along and will no doubt speak again.
160w/m2
15 Amp
Lifetime
Radiant
55
Cut The Cable
Cross the cables
10mm
30-45 Mins
10m2 or 20m long
