Stone and tile cleaning products from LTP.
DHTiling
LTP Grimex
Description: LTP Grimex is the answer to stubborn grime, old layers of wax or acrylic and even rubber sole marks on terracotta and natural stone flooring. Suitable for use on glazed and unglazed tiles, this product is excellent for renovating old quarry tiles, terracotta, slate, stone, marble and stone fireplaces.
Tips: Pick this product if you have stubborn dirt and grime, greasy films, dirty grouting, old layers of acrylic sealers and wax, rubber sole marks on glazed ceramics and porcelain, old and tired looking tiled floors, soot marks on stone fireplaces...
Technical Data Sheet (PDF)
LTP Grout Stain Remover
Description: LTP Grout Stain Remover is the solution for removal of cement and grout residues and is extremely effective against mineral salt formations (efflorescence). Useful for routine cleaning of patios and other outside paved areas, LTP Grout Stain Remover may be used on glazed ceramics, quarry tiles, terracotta and some stone.
Tips: Pick this product if you have cement and grout residues, mineral salt formations, limescale, water marks, dirty patios and other outside areas. Do not use on limestone or when underfloor heating systems are in operation. DO NOT USE ON ACID SENSITIVE SURFACES.
LTP Power Stripper
Description: LTP Power Stripper is one of the few products on the market capable of breaking down oxidised boiled linseed oil from the surface of terracotta. With powerful amines, ammonia and alkalinity that penetrate and help lift the hardest, heaviest films, it is ideal for intensive cleaning of heavily contaminated vitrified quarry tiles, glazed ceramics and porcelain. Strips most things first time thereby minimising labour costs.
Tips: Pick this product if you have heavily soiled surfaces, old layers of sealer, oxidised boiled linseed oil, residual grout on the surface of limestone....
LTP Solvex
Description: LTP Solvex is a powerful non-caustic stripper that softens most types of surface sealer, which can then be removed with ease, suitable for removing most wax, oil, emulsion and polyurethane sealers. Will not discolour or damage natural stone, slate, terracotta or quarry tile surfaces. After washing and rinsing, surfaces are ideal for re-sealing.
Tips: Pick this product if you have stubborn layers of polyurethane wax, Silicon wax, natural wax, paint spots, varnish.....
LTP Spot Stain Remover
Description: LTP Spot Stain Remover is effective at removing the majority of mineral oil and cooking oil stains (including oil spatters). Suitable for use on quarry tiles, terracotta, limestone, bricks, cement and paving. Combine with LTP Fullers Earth to help remove older cooking oil stains.
Tips: Pick this product if you have spot stains from hot oil and other absorbed domestic spillages....
LTP Fullers Earth
Description: LTP Fullers Earth is an ultra-absorbent stain remover for all greasy stains (oil, grease, make-up, sebum etc.). For use on fabrics, leather, porous floors, stone, terracotta and wood. For stubborn stains on flooring combine with LTP Spot Stain Remover.
DHTiling,
DHTiling,
DHTiling,
DHTiling,
