Plywood Expansion Gap
Boondocker
Hi all, new member here.
Some quick questions re 18mm plywood subfloor which will have 6mm insulation boards (marmox) fixed on top.
What should the expansion gap be where 2 sheets of ply meet if one is needed at all and at outside edges where the ply meets the wall?
If a gap is needed what should it be filled with to stop the adhesive used to put down the insulation board getting into the gap?
Any adhesive recommendations? I presume a single part flexible cement based one is needed.
Thanks in advance.
Hi @Boondocker
If you're going to be insulating the Ply from your UFH it's not necessarily critical to allow for dedicated expansion in your ply. However, use a 3mm tile spacer when fixing/installing your ply sheets.
Again there is no real need to fill these joints with anything specific. Use a single part flexible adhesive to bond your boards down and this will be sufficient.
Boondocker,
AliGage,
Boondocker,
AliGage,
