Currently reading:
linaseed oil??
Discuss linaseed oil?? in the UK Tiling Forum area at TilersForums.com.
K
kaharrison9
Hi all.
Would appreciate your thoughts.
I've been asked to try and improve a honed slate floor that was done by another tiler.I've to rake out the grout,seal then re-grout.i was planning to use Lithofin slate seal but the customer was told from where he got the slate from(quarry in lakes) to use linoseed oil.Is there any reasons not to use linoseed oil?
Also what sort of shine does Lithofin slate seal give?the customer is not wanting a high gloss and finally from experience whats best way to apply-roller,brush or lint free cloth?
Cheers for any help
Kev
Spud
linseed oil is a bit old hat these days and after a while the oil oxidises and darkens on the surface of the tile , there are so many good sealers on the market these days, every tiler has ones they like to use, you will not go far wrong with lithofin , fila , aqua mix and ltp iron wax is quite good on slate , i dont particularly like Hg products find them hit and miss although golv polish isnt a bad product
hope this helps
K
kaharrison9
Hi all.
Apologies for asking more on the sealing subject.
Had decided to use lithofin slate seal but the more i read up on lithofin products wondering if perhaps i'm wrong in doing so.
I haven't mentioned earlier in the thread that it is for an ensuite area with a shower cubicle.The slate was put down one year ago by an all in one plumber/tiler/elecrtician and never sealed(also grout lines between 3-10mm and the cuts!!).The slate is smooth,honed, doesn't seem very porous and i take it has been polished.
I spoke to lithofin and they suggested not to use slate seal as over time the sealant will go white coming in contact with water.
They have suggested lithofin wexa to clean the year long grime off,then 4 days later colour intensifier,then next day stain stop,grout then stain stop
The customer has realised it's been a very poor job and has asked if i can simply improve and finish.
Any thoughts should i go through the correct time consuming process or will slate seal intensify and seal?
On the positive side i've learned plenty on slate and gained experience on wether its worth taking on others bad workmanship.
Thanks for any thoughts
Kev
Reply to linaseed oil?? in the UK Tiling Forum area at TilersForums.com
  • Sticky
