Discuss kerakoll in the UK Tiling Forum area at TilersForums.com.
TT Tiling
hello all ,just asking if any of you have used any of the kerakoll range ,as i might be useing some soon ,just looking for the do"s and donts
P
Peter
Used it quite a bit. Never had any problems with it, although would advise laths/starting from bottom cut if you're using the H40 Tenax as it doesn't hang particularly well.
Ajax123
1,213
Lincolnshire
Yep I used Kerakoll H40 Ideal and have seen it used in quite a few installations now. Good stuff on anhydrite. I have seen it used with and without primer and so far so good no issues.
Only issue which I think not really an issue is it isn't rapid set
TT Tiling
thanks guys ,was told you can go str8 down with no sealing ,will let you all know how it goes , got 34 sm slate to do and 90 sm trav to do ,the rep said the grout was a bit dif to use ,leave till finger dry before cleaning off
Reply to kerakoll in the UK Tiling Forum area at TilersForums.com
