Discuss Keracolor FF vs Ultracolor 1.5mm Joints in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi, we are tiling the back wall of our new shower enclosure with 33x33cm ceramic gloss tiles (photo attached). The catch is they have a mosaic effect false grout line through them, lines measuring around 1.5mm. As a result I want to use a 1.5mm spacer between tiles so there is no distinction in the gaps. Ultracolor specifies a 2mm grout line minimum but seems the better grout. Will I get away with it in 1.5mm? Is it too thick to lie in the false lines and stay-put? Would Keracolor be better? Thanks in advance.
Reply to Keracolor FF vs Ultracolor 1.5mm Joints in the Adhesive and Grout area at TilersForums.com
Lowpaul22
