It is used as a subfloor, it's anti crack and waterproof 100%. If your floor is timber, then it is highly recommended to install the Ditra matting membrane. If the floor is concrete you don't have to unless it's cracked.
A decoupling membrane is used to eliminate lateral movement.
I use a decoupler when tiling onto heated screeds to allow the tiles to move independently to the screed so as to avoid expansion cracks.
If tiling onto timber substrates I would use 6mm cement boards as they act as a decoupler but also enable a more suitable and sustainable substrate.
