Discuss Conservatory expansion gap in the UK Tiling Forum area at TilersForums.com.
N
NW tiler
Got a conservatory floor to do next week. The customer wants to leave the brick walls exposed as a "feature" therefore there will be no skirting board to hide the expansion gap under.
Was thinking about siliconing around the edges but it won't look right.
Any ideas?:huh2:
F
fergie
i would mask round the bottum of the wall with tape before you grout as to keep walls clean if the floor is concrete then grout as normal if it is wood then silicone would be better as you can get a good range of colours to match
DHTiling
Grout around the walls and silicone up against the plastic doors.........as long as the tiles aren't cut tight to the walls you will be fine.......
CJ
Points
1,088
Somerset
Carefully grout up against the walls................when sponging off..........1 wipe then rinse to avoid staining the brickwork.....it will take in some water from ya sponge, but that drys
CJ
Points
1,088
Somerset
Try scribing around each brick :)
CJ
Points
1,088
Somerset
Did you scribe that with an Axe..?....:lol:............nice scribing....:grin:
Cheeky git :grin:
Wall on that job bellowed out at the bottom..............and chuffing hard porcelain which knackered my wrists as well as a pair of snips:whatchutalkingabout
Reply to Conservatory expansion gap in the UK Tiling Forum area at TilersForums.com
