Discuss Chimney Breast Split face mitring in the Canada Tile Advice area at TilersForums.com.
P
paul3944
Hi, looked at a couple split face jobs recently where the customers want them to wrap around the chimney breast.
I would usually fit a solid strip (wood or trim) to the edges to avoid mitring. This didnt go down to well and i havent heard from them since....
Just curious to everyone elses approach with these.
Paul
Q
Qwerty
Yes, mitre at the corner and join up with offcut on next adjoining face. If that offcut is too small then replace with a longer piece of identical/ similar look & appearance. I often measure, cut and lay it all out on the floor first (space permitting of course!
P
paul3944
Thanks for the quick reply. Whats your preference to fix, resin or sheeted? Thats if youve got the option of course
Time's Ran Out
Always mitre!
P
paul3944
Top Job there John. Would you recommend some type of matching resin/caulk for the slight imperfections in the mitre joints?
Reply to Chimney Breast Split face mitring in the Canada Tile Advice area at TilersForums.com
