Currently reading:
Child "Safety" Plug Socket Covers - Who uses them?
Discuss Child "Safety" Plug Socket Covers - Who uses them? in the UK Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,055
1,323
Staffordshire, UK
I had a bit of a shock last night reading this: http://www.fatallyflawed.org.uk/
With a 8 month old daughter I was just about to kit out the house with these as she's starting to get around now.
Turns out plug sockets are a lot safer with no covers on them at all. And the covers don't conform to the BS standard for sockets and plugs, there's a bit of a loop hole in the BS.
I'm now supporting the campaign with ElectriciansForums.co.uk and will be letting my family know about it at least.
Dan
Admin
Staff member
5,055
1,323
Staffordshire, UK
There is about 3 hours reading and video watching on there. Very technical stuff, but that might put some people off reading it all. So I've suggested he makes a downloadable PDF leaflet that sparky's can hand out to clients with children. So when he makes it, I'll link you to that too. That'll make it more clear and then if your mum wants to read the lot there's always the website too.
[video=youtube;c82O8bI6u0c]http://www.youtube.com/watch?feature=player_embedded&v=c82O8bI6u0c[/video]
Once a baby has it in their hand, they will often try to put it back in and generally play with it. They'll open the shutters that are designed to only be opened when inserting a plug, meaning they leave the live open.
So best to leave the plug cover out of the equation and simply remove all plugs around the plug socket so the baby can't play with them.
Olz
Haven't read it but i was told a while back that the third pin (top) is just there
to open the cover in the socket to allow the socket to work and the plug to go in, which is why it's commonly plastic instead of metal like the other two.
I was trying to use a plug on which the top pin snapped off and it
Wouldn't physically push into the socket because the third pin wasn't present. so the lower two pin holes covers weren't retracting.
Pretty simple design when you think about it, but an absolutely genious idea and one most people won't realise exists!
Sent from my iPhone using Tapatalk
Dan
Admin
Staff member
5,055
1,323
Staffordshire, UK
It's only scissors that can get the socket open, and at the same time be pushed into the live feed.
The top pin is an earth I believe, but not all appliances need it (lamps etc). So it does physically do something too with some appliances (kettles and high wattage items I assume?) but it's a clever design really.
European two-pin plugs must be a nightmare for kids being shocked as I guess you only need a fork or something to connect to the live. Might be wrong there, there might be some safety mechanism built in - I've not got an adapter to hand to have a look at.
Reply to Child "Safety" Plug Socket Covers - Who uses them? in the UK Tiling Forum area at TilersForums.com
