Discuss Anyone used Rubi TC-180 on Guide Rail? in the Tile Tools | any Country any make any model area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
jjack
Hi,
I bought a Rubi TC-180 cutter and the 1200mm Guide Rail.
After installing the Rubi blade that came with the cutter and then mounting the cutter correctly on the guide rail I was surprised to see that the blade is making a lot of contact with the rubber strip which runs down the cutting edge of the guide rail. I tested the cutter by briefly running it for a couple of seconds and it has shredded some of the rubber strip.
Is this normal? Is the blade meant to actually make contact with the rubber strip on the edge of the guide?
regards
Harry
jjack
Rubi confirmed that this is normal and that the rubber is oversize and is meant to be ground down on first couple of cuts.
Reply to Anyone used Rubi TC-180 on Guide Rail? in the Tile Tools | any Country any make any model area at TilersForums.com
Dawz84
