Discuss Forget the Wet Sponge Idea in the Canada Tile Advice area at TilersForums.com.
Filip
498
Midlands
I have come up with a DIY constant water supply with a pressure sprayer / pipe and a 1ml syringe with the finger end cut off and a blunt needle. The flow of the water is controlled by the position of the elastic band,I just roll it further down putting more pressure on the trigger. I will either fix it to the tile to be cut and aim at the blade or attach to the grinder and point at the blade from there making sure that it is very secure of course. I can use an even finer needle for a thinner and longer water jet so I can keep it well away from the blade
Filip
498
Midlands
Obviously going to be careful about how much water is going to be flying around. I am not as skilled as others holding a heavy grinder in one hand and rubbing a wet sponge directly on the blade with another whilst trying to cut a straight line, I like to keep two hands on the tool.
Filip
498
Midlands
I don't think so, but if it is, it's very poor quality !!
What you are seeing is real grass raked to within an inch of its life then reseeded and then the pigeons eating all the seed :mad: so it is looking a little sorry for itself right now.
Reply to Forget the Wet Sponge Idea in the Canada Tile Advice area at TilersForums.com
