Discuss Where do you empty your buckets? in the Tile Adhesive / Grout Advice area at TilersForums.com.
Tile Shop
When doing a tiling job, DIY or otherwise, its inevitable that you are going to have cement-tainted water buckets either from grouting or cleaning tools/mixers, so where do you empty it out before the bucket goes back in the van or in the shed?
When I first started in our showroom 18 years ago, I was tasked with doing display boards and grouting them. After cleaning it off, I used to tip the water down the drain in the road at the front of the building. After a few weeks, it blocked and cost my boss (so he told me) about 750 squid to get it sorted by the council. Schoolboy error! I then just used to tip it in our skip after that.
So what do you do at customers or your own houses? chuck it down the bog? stick it in the drain? lob it in the bin, empty it behind the shed where you think no-one will see it (this is where mine went when I did my conservatory)? throw it over the plants, or the lawn? Over the fence whilst strategically guessing where next-doors dog might be standing when the water hits deck? Drink it? (can't be worse than the effects of a slightly off pint of Speckled Hen)
What do you do?
Concrete guy
I used to empty as much water out as possible then scrape the rest of the slop out into a builder bag that went to the tip.
That's if a skip wasn't available.
Mind you this was back when you didn't need a licence to take your empty lunch wrappers anywhere in your van and we could just rock up to the local tip and slip the chap a tenner to use the facilities.
Spare Tool
As Alan, leave the bucket or wasboy to settle for as long as possible, pour off water down a land drain, then scrape out what's left into a used adhesive bag or bin bag and throw it in the bin.
Normally sacrifice a BAL mixing bucket which is used to collect all the cack. Decant the water each day carefully down a drain and at the end of the job the bucket is mainly solids. Sometimes Chuck the buckets, if I've time I'll save them.
Down the drain on the street, unless it's a real bad one that I've been cleaning the mixer in, then I do as above, pour the top of and scrape the thick sediment into skip or alike
Pretty much the same as above, often just ditch the bucket along with the slops.
A £1 to throw away a bucket is a lot less than having to pay for drains to be unblocked.
Italy
where it empties intestines, When he leaves the sh.t? and have no toilet?
put everything, same place, same as above.
widler
1,328
England
1st day of my apprenticeship, i emptied a dirty bucket down a drain, right next to a council suit, i got marched back to my boss , he got a rollocking , i got a bigger one .
Stuck in my mind to this day.
Gardens, bushes,spare land , full skips, but never ever drains :(
Reply to Where do you empty your buckets? in the Tile Adhesive / Grout Advice area at TilersForums.com
