Discuss Bisazza Fillgel in the Tile Adhesive / Grout Advice area at TilersForums.com.
Italy
I'd like to know how you treated fillgel bisazza or epoxy. use of tricks? I am young tiler seek advice;)
thanks
New Filgel is easy! :)
Water! :rolleyes: Aqua!
And use sponge cloths like this, not Tilers sponge.
Tilers sponge soak up too much epoxy, throw away quickly.
Sponge cloth, lasts much longer.
Then use 'Shine',
if you can not get it,
then use your nail polish remover Antonio to remove residue! :D
Italy
Then use 'Shine',
excuse me but marc epoxy and 'hard to spread, you have solutions?
thanks mister 3_fall
MTiler
Use plenty of white emulsifying pads and sponge cloths, as Marc mentioned using normal sponges is a waste as they just clog up. Use warm cleaning water if possible and use plenty of clean water. Put a cup full of white vinegar in the water, and give a final wash down with just plain water. White vinegar in water to clean tools also helps. I now use it instead of acetone to clean up.
As soon as youve finished applying the tub of filgel/epoxy clean it off dont wait.
Always wear Nitrile gloves and try not to get it on your skin, if you do clean it off straight away as it can burn, its toxic stuff. Im sensitive to it so I always wear two pairs of nitrile gloves a long sleeved tshirt and a mask.
If you need to remove any dried epoxy you can use a heat gun to soften it. Ive not used Mapies' epoxy remover so I dont know how good it is.
Any epoxy grout is nasty stuff.
Sharon
Italy
OK OK.
I started this trend because I wanted an answer from @MissTiler
professional mosaic.
I was interested if you use special tricks to make fillgel easier to pull.
Former keep warm or cold before mixing?
cleaning I have no problems.
I'll try with sponge cloths.
This might be fine?
Maintenance
ringrazio @3_fall and @MissTiler :)
Reply to Bisazza Fillgel in the Tile Adhesive / Grout Advice area at TilersForums.com
