Discuss Grey wide joint in the Australia Tiling Forum area at TilersForums.com.
dboden
493
Nottingham
I usually use weber wide joint for floors on concrete.. but the customer wants a mid/dark grey, but weber only do silver.
Can anyone recommend a grout, how dark is the bal grey once dried?.. Or TA flexigrout?
ps, I hate using Mapei.
Stef
Grout 3000 is a great grout, easy to use on walls & floors & doesn't slide off your float.
Don't panic about the colour of mid-grey once mixed as it looks quite purple but is good once dry.
dboden
493
Nottingham
I use Grout 3k all the time to be honest, it is my grout of choice for 90% of stuff... I suggested mid-grey, but he wants it darker!..
I have ended up buying Mapei Anthracite from EMC today..
tbh I,ve only ever used Mapei on walls and hate it, I,m hoping it won't be as bad on floors????
fingers crossed.
Stef
fingers crossed.
Mapei is good on floors, as you say i hate using it on walls as it just slides off the float.
I mix Mapei tight now & then add a spot of water if needed after 5 mins or so.
Reply to Grey wide joint in the Australia Tiling Forum area at TilersForums.com
