With BAL Rapid-Mat, you’re installing: Tilers Community
  • Thread starter Thread starter TilersTalk Admin
  • Start date Start date
TilersTalk Admin
With BAL Rapid-Mat, you’re installing by Dan Williams
With BAL Rapid-Mat, you’re installing with a thin, lightweight uncoupling system – making your life easier! Rapid-Mat is only 0.8mm thick – perfect for when minimal height build-up is required. This compares with traditional cavity mats which are typically 4mm thick, with a layer of fleece bonded by mesh to an upper layer. Being only 0.8mm thick also means that BAL Rapid-Mat 30m rolls are smaller and lighter than traditional cavity mat system. At only 8.5kg per roll, compared to 16-18kg per roll respectively, this means they are not only easier to carry...
Read more
The rest of this thread about "With BAL Rapid-Mat, you’re installing" is available by clicking here
RSS fed thread from Tilers Talk | Tile Bulletin Board
Tiling Forum for UK
Tilers Talk - Any Country
Tags Tags
None
TilersTalk Admin,
TilersTalk Admin,
