Discuss Help! in the DIY Tiling Forum area at TilersForums.com.
julie bw
Any advice please. I had porcelain tiles put in my bathroom 12 months ago. Gradually on one wall they have started to lift and are rocking when touched. The wall behind these tiles is clinker block that has been skimmed with plaster. Can anybody advise me why this has happened and will the tiles be able to be put back on again. thanks
Q
Qwerty
Can you please take a photo of a tile off of the wall with a photo of the wall and the rear of the tile also
julie bw
Hi Julie , it could be a number of issues , do you know firstly what adhesive was used ?
Hi dave he used pva on the wall then used flexible adhesive. On the other 3 walls that are solid brick the tiles have not moved.
julie bw
Hi plan tec tiling.the tiles are being removed next wed.the fella only wants to remove the main lose ones.they all sound hollow behind the tiles when you knock on the them
White Room
Skimmed with a single plaster coat or a two part plaster system ?
White Room
If he has done the above spot fixing...yes he would be to blame and why use pva.
Reply to Help! in the DIY Tiling Forum area at TilersForums.com
