Discuss What is the correct tile spacing for wall tiling? in the UK Tiling Forum area at TilersForums.com.
Dan
Admin
1,318
Staffordshire, UK
The correct tile spacing for wall tiling is a minimum of 2mm. The maximum will depend on the tile size tolerance and the tile grout used. The thicker the spacing and the deeper the tile, the more coarse grout you require.
Smiths
Admin said:
The correct tile spacing for wall tiling is a minimum of 2mm. The maximum will depend on the tile size tolerance and the tile grout used. The thicker the spacing and the deeper the tile, the more course grout you require.
I always use 2 or 3mm spacing on wall tiles.:)
m3 fitter
1mm is usually for marble or polished limestone, to try and achieve a sheet face look
Reply to What is the correct tile spacing for wall tiling? in the UK Tiling Forum area at TilersForums.com
