Currently reading:
Sealing a Slc garage floor prior to painting
Discuss Sealing a Slc garage floor prior to painting in the Canada Tile Advice area at TilersForums.com.
H
hmtiling
I used Mapei Ultimate Leveller 1210,my first time using a Slc so wasn't sure what to use so didn't go for the top end stuff did it on a budget so prob wasn't the right stuff to use I'm guessing.
I don't think that is suitable . Tilemaster external leveller is suitable and reasonably priced . You could prime and put a coat of that on top . unsure about how thick that would need to be but @Glynn will know
Reply to Sealing a Slc garage floor prior to painting in the Canada Tile Advice area at TilersForums.com
