Discuss What do you use to mark your tiles for cuts... in the UK Tiling Forum area at TilersForums.com.
DHTiling
What do you use to mark your tiles with for cuts etc...do you use felt tips....lead pencils...china pencils.....what do you find best..??????
do you use different on mat and glossy tiles...etc etc.....
bencurtis
all different depends on tile, but my sons crayon style pencils are good for wet cuts.:yes:
Ric
i use lead pencil then score line with dry cutter, wet saw follows line nicely, but would like to know if there is anything better to use.
GazTech
marking out..tile face
If snapping glazed tiles.ohp pens permanent, rub the mark off the tile if it is still visible after the cut....If the tile is satin face...pencil..(2 tiny marks top and bottom of tile)....Gaz
brummie tiler
i use pencil and felt although felt is rubbish when you go to put it on the wet cutter!
ged
i ran out of marker pens on a job, but i bought a tipex pen from sweet shop and it worked great never lost the line in the wet cutter. Easy to buy when your miles away from a tile shop
ged
grumpygrouter
ged
Good tip that, bit hard on white tiles though!!:grin:
Grumpy
penno
I always just use a pencil, even on dark tiles. Can always see it even if you use a wet cutter because it gives off that shine (providing you keep your water clean)
Reply to What do you use to mark your tiles for cuts... in the UK Tiling Forum area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
  • Sticky
