Discuss What do you use to mark your tiles for cuts... in the UK Tiling Forum area at TilersForums.com.
C
cowboy
We use pretty much the same things herr in the states as you folks do over there.
I use pencil mostly & use the pencil/score trick as mentioned as well but the best thing I use for wet cuts on dark tile & most stone is a "White-Out pen" as found in office supply houses for covering up mistakes on paper? . Not sure what they may be called in the UK but Presto Ball point makes a version & I believe Bic too?
Reply to What do you use to mark your tiles for cuts... in the UK Tiling Forum area at TilersForums.com
  • Question
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully screwed in. The Tiler laid my 5mm hex mosaic tiles on a 2mm bed, so obvs wasn't going to drain. I took...
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
  • Sticky
  • Question
