Discuss Zamora Brown (Topps Tiles) Megastone 300mmx600mm in the America Tile Forum area at TilersForums.com.
Hello Manny,
Did you have any luck with this. I'm looking for the same. Only need four tiles, could get away with just two at a push.
Thank you & Good Luck
Hi Paul,
no luck yet, still hoping I can get some. Good luck, if you come across more than four let me know, likewise if I come across more than what I need, I’ll let you know. There must be loads of unused boxes/loose tiles of peoples homes some of which will be what we’re looking for; they just do not know about TilersForms.com or the fact that someone might be looking for some some old tiles.
Hi All,
New to this Tilers forum... hoping someone can help me out...
I'm looking for some Zamora Brown Tiles they were sold in Topps Tiles and were made by Megastone
Size I need 300mmx600mm (30cmx60cm).
Does anyone have any spares?
Manny
Hello,
I only have 30 X 30’s.
Reply to Zamora Brown (Topps Tiles) Megastone 300mmx600mm in the America Tile Forum area at TilersForums.com
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
  • Question
  • Question
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
  • Sticky
  • Question
