Currently reading:
Used Modified under Ditra on concrete by mistake. Options?
Discuss Used Modified under Ditra on concrete by mistake. Options? in the DIY Tiling Forum area at TilersForums.com.
gamer1
London
Using modified thinset under Ditra can potentially cause bonding issues because modified thinset doesn't fully cure when sandwiched between two impervious surfaces like Ditra and porcelain tiles.
Here are your options:
Remove the Ditra: You can choose to remove the Ditra from the areas where you've used modified thinset. This can be a labor-intensive process, but it ensures proper adhesion.
Overlay with Uncoupling Membrane: Another option is to apply a layer of uncoupling membrane over the Ditra that has modified thinset. This can provide a separation layer and allow you to proceed with your tile installation using unmodified thinset.
Consult a Professional: If you're unsure about how to proceed or if you're concerned about the quality of the installation, it's a good idea to consult with a professional tile installer who can assess the situation and provide guidance.
In any case, it's essential to address this issue before continuing with your tile installation to avoid potential problems down the road.
Reply to Used Modified under Ditra on concrete by mistake. Options? in the DIY Tiling Forum area at TilersForums.com
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this, The property unfortunately flooded throughout. Now although I'm told it's all dry now I'm reluctant...
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which is very thick concrete. He wants electric underfloor heating but I'm concerned he'll lose too much...
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
