Currently reading:
under floor heating mat
Discuss under floor heating mat in the UK Tiling Forum area at TilersForums.com.
K
kenking
:yes:I've just finished my first ufh job (my own bathroom) and was pleasantly surorised by the ease of handling of the electric mat, cutting the support mesh to bend the mat around to fit the floor shape etc. Use a rubber or plastic float and just squeegee flexible tile adhesive thru' the mat to just cover the conductor cable. Let it firm up, then add your combed adhesive layer and bed the tiles onto it. Easy-peasy! You'll find it so, I'm sure.
Reply to under floor heating mat in the UK Tiling Forum area at TilersForums.com
Good morning all. After a little advice. I'll post pictures a bit later. However.... The homeowner of the property I'm working on has just come to me and asked if anything can be done about...
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully screwed in. The Tiler laid my 5mm hex mosaic tiles on a 2mm bed, so obvs wasn't going to drain. I took...
