Discuss Rubi du 200 evo in the Canada Tile Advice area at TilersForums.com.
Points
38
Medway
Hi
Has anyone got or used the Rubi du 200 evo 650 electric Cutter, I was thinking of purchasing one as I've had my one for years and it's on it's last legs, or could anyone advise me of a decent cutter? Thanks
Points
38
Medway
Well to be honest I have just bought a Rubi ts max 75 I did borrow one a little while ago thought it was decent never used a sigma to be fair I take it you don't use a wet wheel cutter then lol
J Sid
I do for stone when needed. As for rubi, I used them for a good 25 years till I tried a simga:rolleyes:
GoneGuy
I’ve got one, I only use it occasionally mainly for envelope cuts.
I find the motor seems a bit underpowered and it’s hard to line up for cuts.
I’ve been looking at getting the newer model of rubi bridge saws
Points
38
Medway
Alright cool does it cut porceline
alright cool does it cut porceline okay?
What other cutter do you use then?
GoneGuy
Yes it does and I’ve cut 12mm thick marble on it.
I use a grinder a lot with specific blades for various materials, but looking to get a newer bridge saw mainly just for envelope cuts
Reply to Rubi du 200 evo in the Canada Tile Advice area at TilersForums.com
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson...
