Discuss Ripping out existing floorboards in the Canada Tile Advice area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Depends if they're tongue and groove or not. If they are then claw hammer and crowbar if they're not I'd take the first board out with a hammer and chissel/lever then take the rest out with a pallet breaker which would preserve most of the boards for reuse.
One Day
Just one of these:
Reply to Ripping out existing floorboards in the Canada Tile Advice area at TilersForums.com
Hello, I am about to waterproof an existing shower after taking out all of the old tiles and old mud waterproofing. From what I see there is an existing drainage. The idea is to clean everything...
  • Question
Good morning all. After a little advice. I'll post pictures a bit later. However.... The homeowner of the property I'm working on has just come to me and asked if anything can be done about...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
