Discuss Removing Grout Stains From Encaustic Cement Tile in the Australia Tiling Forum area at TilersForums.com.
andy-p
Points
543
Central Scotland
Fixed 15m2 of handmade encaustic cement tiles supplied by the Cement tile shop and like a complete jackass went and grouted tiles before sealing , after cleaning up saw that tiles were stained then checked suppliers website only to find out seal before grouting , is there a cleaning product that would remove or i will they need mechanicaly polished ? any help would be much appreciated .
Lithofin BOB
Points
508
Hampshire
Getting a few of these at the moment, finicky things!!!!!
You could try a non acidic residue remover, we have lithofin power clean, this is a light alkaline, others makes avalible,
Try it 1-1 or even neat with a white pad, test one tile unlaid first then one tile laid,
All about the test, let test dry if all ok work small sections
I have been testing neat power clean and a green pad on these tiles removing black grout from these tiles , but!!!! A green pad can change the surface finish on some makes of tile, but did in a few cases remove the contamination.
Might be worth picking one up . With the white if you don't
If this works , leave the tile 7-9 days or until fully dry before you impregnate with your chosen product.
andy-p
Points
543
Central Scotland
Hi , update here , tried various cleaners including the lithofin power sripper but the grout was too ingrained
Only solution was too rub the tiles down with diamond pads and plenty water , hard work but job done and a happy client , probably easier done with a grinder polisher but got there in the end
Thanks for help BOB...
Reply to Removing Grout Stains From Encaustic Cement Tile in the Australia Tiling Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
