Discuss New DIY geek needs underfloor heating in the The Welcome Forum area at TilersForums.com.
Skinnyindian
Try electricians forum ?
Personally wouldn’t touch anything to do with electrics, not worth saving £40 to potentially killing the next owners of your property.
Sorry it was late and I didn't read through it! I wanted to know if buy a kit can I change it to fit such a small space? Else I will end up heating under the toilet pedestal, the saniflow and the cupboard for the pipework. 500 X 600 is the space which is open for use.
Uheat - Jake
TF Official Sponsor
143
743
500 x 600?!
:tearsofjoy:
Just light a tea light.
You don’t use standard UFH with laminate, you use the Foil back stuff. Wrong forum for this really.
A standard UFH Cable or Mat can be used with Laminate. As long as the cables are encapsulated in a 8-10mm Flexible SLC.
Unfortunately for a 0.3m2 area there is nothing we can provide and nothing I know that our competitors provide either unfortunately :(
Skinnyindian
A wet underfloor heating system can also be used with Laminate but I really don’t think this is what the OP is suggesting.
I wanted to know if there was a system which I could utilise in such a small space as it does get quite cold in there. Everything is factory built and I am not sure it can be altered or shortened in any way. Would have used electrical if there was a chance that I could simply cut it down to the size I needed. Perhaps pipes could work. Will check plumbing and sizes to see if can indeed use them.
Reply to New DIY geek needs underfloor heating in the The Welcome Forum area at TilersForums.com
