Discuss New DIY geek needs underfloor heating in the The Welcome Forum area at TilersForums.com.
Skinnyindian
Really enjoy DIY. So much so that I am finding new things to do even if they don't need it.
Joined this forum to see if I could discuss how to make my own underfloor heating for laminate flooring or if I buy a mat, 500mm X 600mm.
Time's Ran Out
Try electricians forum ?
Personally wouldn’t touch anything to do with electrics, not worth saving £40 to potentially killing the next owners of your property.
Skinnyindian
Sorry it was late and I didn't read through it! I wanted to know if buy a kit can I change it to fit such a small space? Else I will end up heating under the toilet pedestal, the saniflow and the cupboard for the pipework. 500 X 600 is the space which is open for use.
The Tiler
you can get loose wire kits to fit an area of 1m2. The wires maybe able to be put closer together to fit your smaller available floor space. Check with the supplier if they recommend doing this when you order
Uheat - Jake
TF Official Sponsor
Points
743
500 x 600?!
:tearsofjoy:
Just light a tea light.
You don’t use standard UFH with laminate, you use the Foil back stuff. Wrong forum for this really.
A standard UFH Cable or Mat can be used with Laminate. As long as the cables are encapsulated in a 8-10mm Flexible SLC.
Unfortunately for a 0.3m2 area there is nothing we can provide and nothing I know that our competitors provide either unfortunately :(
Waluigi
A wet underfloor heating system can also be used with Laminate but I really don’t think this is what the OP is suggesting.
Reply to New DIY geek needs underfloor heating in the The Welcome Forum area at TilersForums.com
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this...
