Discuss New Build UFH Tiling in the DIY Tiling Forum area at TilersForums.com.
John Wingfield
Hi all
First post on here as need some advice. We are building a house and have got to the point where the floors need tiling.
The floor is a sand and cement screed that was NOT poured. It has been in the house since August.
The screed contains water based UFH which has not yet been turned on / commissioned.
I am going to be doing the tiling - done plenty before in previous houses, but never onto a screed with UFH. The chap in charge of the build has stated that we need to use a decoupling membrane on the screed to stop the tiles cracking.
I dont believe this is required, as the screed has had plenty of time to dry out (5 months) and I will have expansion joints between each room between the doorways.
Just after others experience / advice on this topic?
John
John Wingfield
Im not using a tiler, Im doing it myself. Ive done a fair amount of tiling in previous projects over the last 3-4 years, but never on UFH screed, so I wanted to do my homework and hence seek advice from the forum.
Thanks for all the thoughts. Im not using stone, just porcelain tiles,
I will ensure the heating is properly commissioned before laying the floor and will be purchasing a matting, now that I have the facts.
Commisioning is very important , as on the first heat up of the ufh , you not only get lateral movement but also vertical - deflection .
1. The worst of the vertical happens on the intial heat up.
and
2. Ditra or any other decoupling mat for that matter don't really allow for vertical movement only lateral ( if memory serves me correctly). So if you just put down a mat without the commisioning you could still get probs later.
Diggy
Dumbo
I wouldn't be so sure you can't claim back vat on labour provided any contractors u used are vat registered . I'm sure the ground workers would of been . Probably be wise to talk to some friends and have a meeting with a sharp accountant . Not just a friends mate who is an accountant but a good one . You could be looking at getting a lot of money back . Ditra will seem like a drop in the ocean
Dan
Admin
5,039
1,323
Staffordshire, UK
Reply to New Build UFH Tiling in the DIY Tiling Forum area at TilersForums.com
  • Question
  • Question
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
  • Sticky
  • Question
