Discuss Metro tile spacers, 4mm. Is it going to look awful? in the DIY Tiling Forum area at TilersForums.com.
Points
36
Staffordshire
hi, doing a diy job of filing our kitchen using metro tiles for b&q. We have started and have used the 4mm tile spacers but now we’ve realised that we probably should’ve used smaller. Is it going to look awful? Has anyone use 4mm before?
We’ve chosen anthracite tiles and white grout. Should we change the colour?
Tiles not quite as dark as photo but attached a photo so you can get an idea.
Thank you, would appreciate any advice
One Day
It's a personal choice but I wouldn't.
2mm normally looks about right.
That said, I have 5mm joints on my kitchen tiles 100x100 rustic ceramics. But the boss picked that - not me!
Spare Tool
2mm or perhaps 3mm it it makes the set out better, you haven't gone too far to start again though..totally contrasting grout will show up every little discrepancy. One thing I will say is do a full row at a time or you could come a cropper jumping up rows before they're completed..
Points
36
Staffordshire
Thank you, other half won’t start again so going with it will definitely go for the darker grout though, good point about lighter grout show up any discrepancies! Will take the white grout back and swap it. Does anyone have any recommendations for a good grey grout?
Have already come a cropper with ending on a tile that needs to be about 2cm wide I’ll hide it with a plant
Spare Tool
Ultra grout in anthracite, or Tilemaster dark grey would be my recommendation..
Points
88
Hampshire
From your photo you've only got 13 tiles to take off and start again.
Find and mark the centre of each wall to be tiled, you can then determine the best way to set the tiles out to avoid awkward unsightly cuts into corners. It's worth spending a bit of time doing this. If you are tiling up to/around/into window sills/reveals think about how the tiles will look. Windows and splash backs behind cookers/hobs/below extractors etc tend to be focal points. You and your other half will be much happier with the end result. Good luck :)
Reply to Metro tile spacers, 4mm. Is it going to look awful? in the DIY Tiling Forum area at TilersForums.com
