Discuss Makita grinder running slow in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
Dumbo
My Makita 18v battery grinder is running half speed ( approximately . I havent measured the rpm ) is this likely to be brushes or something more terminal . Went to check the brushes by removing and inner and outer cap but couldn't do it . Any advice would be appreciated
Sean Kelly
Points
1,068
Ruislip
The outer cap is probably covered in adhesive!! Just use a screwdriver and they will pop off.
The inner ones are threaded. If I remember correctly they have a slot in the middle of them so that you can get a flat head screwdriver and turn them. Failing that use a thin nosed set of pliers to give them a good turn.
Take out the brushes, again by prising them out with a screwdriver.
The slowness of your grinder is probably the worn brushes!
I
Italy
they may not be the brushes,
lately the brushes have a copper wire inside,
when the copper touches the winder, the block is immediate.
the grinder no longer works
Dumbo
It wasnt that bad
About 15min and £11 later its fixed .
Spoke to a local tool guy he reckoned
£30 Labour and about £30 bits .
All parts I used genuine Makita from local builders merchant . At £30 Labour I reckon £120 an hour , nice work if you can get it .
One Day
I always give my tools a clean after use.
You know what they say : Look after your tools - and you'll be late home to an angry wife...
(but at least your tools will be clean!)
Reply to Makita grinder running slow in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
