Discuss Makita grinder running slow in the Tiling Tools area at TilersForums.com.
Sean Kelly
1,068
Ruislip
The outer cap is probably covered in adhesive!! Just use a screwdriver and they will pop off.
The inner ones are threaded. If I remember correctly they have a slot in the middle of them so that you can get a flat head screwdriver and turn them. Failing that use a thin nosed set of pliers to give them a good turn.
Take out the brushes, again by prising them out with a screwdriver.
The slowness of your grinder is probably the worn brushes!
It wasnt that bad
About 15min and £11 later its fixed .
Spoke to a local tool guy he reckoned
£30 Labour and about £30 bits .
All parts I used genuine Makita from local builders merchant . At £30 Labour I reckon £120 an hour , nice work if you can get it .
Reply to Makita grinder running slow in the Tiling Tools area at TilersForums.com
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
