Discuss Low quality floor slab in the Australia Tiling Forum area at TilersForums.com.
N
NigelB
Hi, looking for help with options here. Stripped out old kitchen and lamintate floor to reveal several cracks - rubbish slab really - some small vertical movement as well as horizontal so clearly can't tile direct even with an isolation membrane. New kitchen coming in 6 weeks, can't be delayed, wife insists on tiled floor. No time to rip out and replace slab - and it would take too long to dry anyway. Looking for a less than ideal way that i might get away with. oh and limited headroom too!
Thought of levelling out and fix cracks as best I can, layer of DPM then 22mm chipboard glued as a floating floor, then tile on top using flexi adhesive? maybe with a decoupling membrane on top of chipboard? Any chance that might work? Many thanks
Q
Qwerty
N
NigelB
Thanks for all replies! Well I certainly felt like running away screaming when I saw it, already had to take the walls back to bare brick, insulate, board and skim which I finished last weekend!
I don't think I have time to replace - from what I've removed in the worst bit in the middle there is around 1.5 -2 inches of concrete on a combination of the old brick floor and earth / sand. So I would have to rip up slab, dig down at least 6 inches, pour a slab with re-bar and wait for it to dry enough for insulation and screed. I can't see it would ever by dry enough to tile ahead of kitchen fitting.
Driving force is daughters wedding, she and new family coming over from States early December hence drop dead date for fitting....divorce being the probable alternative! So starting to think best repair I can followed by engineered wood on a proper damp proof underlay may have to be the compromise.....
Ajax123
1,213
Lincolnshire
You can cover concrete as soon as it is hard. Why do you need rebar?? Pour one day cover the next using 1200gauge polythene. Insulate and overlay it with 500gauge polythene then screed using a rapid drying screed. The whole thing could be done in a week...two at the most...
Reply to Low quality floor slab in the Australia Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
  • Sticky
  • Question
