Discuss Large Format - 2 Rooms Meeting At 22Deg Angle At Doorway in the America Tile Forum area at TilersForums.com.
Deleted member 59001
Hi there,
I am looking for advice on tile layout for a new build.
We are putting 600mm x 600mm large format in the kitchen and running it out the hallway.
The kitchen is at a 22Deg to the hallway.
The edges of the tiles will not aligned at this angle and so i am looking for advice how best to have a nice seamless transition from the kitchen to the hall at the doorway. Images attached.
I am trying multiple offsets of the kitchen tile, while wanting to have the hallway tile central.
Grout is 1.5mm
Much appreciated for any advice
Hoping somebody would have any suggestions or best practice ?
Many thanks,
Tom
38
Manchester
Only way I can see is if you can set hallway so joint line is running middle of door opening, then use that joint line as a setting out point for main room, the joint would meet visually at the door opening but the joint line will be effectively changing to a diagonal bond which will run centered through room. Very hard to call without a scalable drawing
Reply to Large Format - 2 Rooms Meeting At 22Deg Angle At Doorway in the America Tile Forum area at TilersForums.com
