Discuss Flexible Adhesive in the Tile Adhesive / Grout Advice area at TilersForums.com.
Terry the tiler
Good evening chaps, I have a quick question regarding adhesive.
So I went to price a job the other day for another customers father, it's a riverside property built on piling all timber frame and unfortunately has a floating floor. Now I told the guy I wasn't happy to tile it explained all the risks but he's adamant he wants it tiling (or his wife does) so I agreed to do it but take no responsibility for any movement and cracking.
To be fair the floor is more solid than you would expect and I have got him to fix hardie backer staggard on top to give more strength and less flex.
It's an area of around 25m and the tiles are 600X600 gloss porcelain.
Now that you know the details I suppose the question I'm asking is what adhesive would you guys suggest I use, I would usually use a Weber or bal rapid spf but I suppose I'm looking for something with a bit more flex.
I plan to also lay a bal or ditra DE-coupling matt down first as well.
Any help would be appreciated, and please don't judge me for tiling a floating floor but this is risk free for me as once I leave it's his responsibility.
Grout ideas would be handy too. I usually go for mapei or bal microflex
Terry the tiler
Su
The fact you have agreed to do the job knowing it may fail, means you will be held responsible if it ever went legal . No matter what has been said or signed between you and the client.
Anyway ditch the ditra and use bal fast flex with bal grout and gt1 admix.[/QUOTE
I'm defo going to get him to sign it off in writing. I'm pretty sure I will be covered then.
That's the whole point of getting it in writing so that I'm protected if he decides to be a chancer.
Tile Shop
Eh?..... that is so not true.
Actually, it is. If a tiler still continues with a blatant disregard for the customers property or safety, a bit of paper with a signature doesn't not mean the customer is in full knowledge of what they are signing or what the consequences may be. The tiler is the expert and if he carries on knowing that what he is doing has a high possibility of failure, he better duck because a book is hurtling in the direction of his head.
Regardless of what bits of paper are floating about with whoevers signature is on it, it can still constitute Wilful Negligence or Wilful Misconduct.
Bill
Why is it not true Tom....
Because each case is taken on merit. The deciding factors will include all evidence of why it has failed. If the client insists that the procedure shall begin, even though the contractor has vetoed that compliance, then that will be taken into consideration by the judge's decision. Nothing is ever black and white.
Dan
Admin
Staff member
5,040
1,323
Staffordshire, UK
We've seen a few cases where the tiler (and plumber on our plumbing forum and sparky on our sparky forum) has lost a case because he shouldn't have done something but the customer said do it. The court see you as the expert, a third-party expert witness they get in to take advice from would say hands down that you shouldn't have done whatever it is if you knew it would fail.
If it isn't acceptable due to safety, the customer signing something is worth jack. You'd be better off not signing anything and denying you even spoke to the customer let alone did the job. (Not that I'm condoning that!)
Tile Shop
Narp, narp narp. completely disagree.
The bit about why it failed, the tiler will explain why it will fail before he starts...... but trots off and does it anyway. Waivers??? a written document of a tiler documenting how and why it will fail, and that he will accept no liability. he has actively documented that that his tiling will not work, to the cost of the customer. Doesn't matter if the customer accepts that or not at the beginning. Its extra written proof that the tiler knew he couldn't do a fault free job.
Ok, so you might get a nice judge, but any sensible person wouldn't even put themselves in that position. And if you don't get a nice judge, you won't be doing it again will you!. And it will cost you more than you earned from the job.
Seen it happen twice. Waivers ain't worth the paper they're written on/
Terry the tiler
Thanks for all your messages chaps.
I understand all your points.
The floor has not got ufh and I'm pretty sure won't pose any threats to health and safety it's more a case of if/when the grout decides to crack, the risks have been explained to the customer.
He is already aware but thinks it will be firm enough.
It was quite a sturdy floating floor and he reckons the neighbours has been tiled for over 5 years and is still fine, so. ..
I've told him we will take every precaution and measure to try and prevent cracking and that's all we can do.
At the end of the day I'll have it laid and grouted in 3 days and once I'm paid, it's his problem. And I mean that in the least arrogant way. Any problems he has after that he has been warned about.
I could write a good letter up explaining all this and that he understands to protect myself I mean at the end of the day I'm not doing anything wrong here.
He's in the wrong for proceeding to go with tiles and accepting the risk.
One Day
How much is the Bal s2 per bag? Very pricey i'd imagine. Everyone does a single part s2 now so i'd shop around. As @Andy Allen says, use an admix with your grout for increased flexibility
BAL Fastflex is the most flexible adhesive there is. S2 isn't really a measure of flex, but more of flexural strength (i'm told anyway)
Some situations call for massive bond strength - so use TM Ultimate for that.
Others call for more flex - BAL FastFlex for me in that case.
I'm with Andy Allen on this one. GT1 with the BAL grout too.
H
hmtiling
Every day's a school day:thumbsup:
Andy Allen
1,318
Gloucester
I've seen it in 12kg bags at Topps and dread to think what it equates to at 20kg. I've heard it's a bit like the old Weber wf21 when mixed.
Biggest big you can get is 12.5 kg but as it's an elastomeric you will still get approx 4 to 5 m2 from a bag with 10mm trowel.
Can't use it with the new bal decoupling mat though..
Reply to Flexible Adhesive in the Tile Adhesive / Grout Advice area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are porcelain. I’ve just got to the end of my bag of Mapei flexible rapid set tile adhesive (powdered)...
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed most of our floor to accommodate tiling 800x800 porcelain over an uneven floor. The gap from defrac...
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
