Currently reading:
expansion joints
Discuss expansion joints in the UK Tiling Forum area at TilersForums.com.
peter241
Hi Geehippy,
Ive been using Expansion Joints for years on site, you dont get much call for them in a domestic premesis tho. on site when working on large areas i tend to put them in every 8 - 10 meters on top of the joint in the floor where the screed or concrete slabs meet, these are usuall 8 - 10 meters square.
They are really simple to insert, its like a lenth of tile trim, you put it down and bed the tile in to and up to it. then you fix the next tile to the other side of the joint. it looks like a grout line. in affect it is!
Expansion / movement joints come in variouse colors, grey, black, blue, yellow. you can even get them in pink :lol:
i hope this helps:thumbsup:
Reply to expansion joints in the UK Tiling Forum area at TilersForums.com
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Sticky
