Currently reading:
Damp proofing concrete floor
Discuss Damp proofing concrete floor in the Canada Tile Advice area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Houses of this age are not designed to have damp proof floors and you could end up doing huge amounts of damage if you are not caareful. Firstly is it modern concrete i.e. made with cement rather than lime. Is there a polythene damp proof membrane underneath it... I hope no but sometime bad things are done in the name of improvement. If not then you have rising damp which a liquid dpm is not designed for anyway. Personally would look for breathable systems like they use a lot in Italy where the buildings are often very old. If you have to damp proof I would look at ditra rather than a liquid system. At least this would allow movement of moisture vapour offering less damage to the building.
Lakey
478
Crawley
Cheers for the response.
There are 2 adjoining concrete floors, one with a visible DPM underneath that ranges from 70mm-3omm and one that is relatively 'modern' and appears to be deeper.
We have already SLC'd and can see no visible damp areas. We will be using Ditra Duo so i'm happy that will deter and moisture from coming up!
Reply to Damp proofing concrete floor in the Canada Tile Advice area at TilersForums.com
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
